1 - 3 of 3 Posts
the steering is fixed! thanks to all who helped.
Now help me, if you would please, understand my PTO. There seems to be two speeds and neutral on my MF35. Which speed do I use for the brush hog?
I know how to raise and lower the mower unit. Do I leave the draft alone?
what does the draft do and which tools do I use it with?
erk what a green horn
Retired - Veteran Mod
Your 2 speeds on your PTO should be labelled 'Engine' and 'Ground'. You want to use 'Engine' when brush-hogging.
Draft mode is used for ground engaging equipment (i.e. a turning plow). For the most part, nowadays... you'll just need position control.
1 - 3 of 3 Posts
