HI,
My bolens 1050 has an oil leak, seems to be coming from the crank seal, but i might be wrong. It is coming out the botom of the flywheel housing, and the oil seemed to be a little high. are there any ports/vents or anything behind the tin? Also if it is the crank seal, will I have to open up the crank case to fix it?
