1 - 20 of 26 Posts
"The Lucky Muscle"
I am looking to have a few filters on hand for my Kohler motor. The Advance auto parts next door to me carries 7 brands. Which would be the best to get? They have the AC Delco, Motorcraft, Mobil 1, Purolator, Pure One, Bosch and the K&N. As noted from other members on the board it isnt really a big deal going aftermarket as long as its good quality. I would go to napa but its a little ways away from me. Thanks!
a friend send this to me ,hope it helps...... Engine Oil Filters Overview
[ Recommended Filters | Filters To Avoid ]
Description
This page now contains my *personal* slant on oil filters. It is largely based on the things I discovered in the Oil Filter Study I performed several years ago. Since there was concern about the influence of some of the subjective information on that page, it has been removed and put into this page. Again, these are my personal opinions and I am just a concerned automotive enthusiast that is tired of being toyed with by these manufacturers. In reality, I am an Electrical Engineer with no qualifications in the area of filtration analysis. However, I have eyes and some common sense, which has proven to be enough to accomplish what I set out to do.
What Makes A Good Filter?
Engine oil filters have one purpose in life: to filter out the particles that enter the oil so that they don't act as abrasives when the oil recirculates. The filter is a cellulose (paper) or synthetic media that is usually contained in a steel can. The front of the can typically has a threaded center with surrounding holes. Oil enters through the surrounding holes, passes through the filter media, and exits through the threaded center. The filters usually screw right onto the engine block using an o-ring gasket to prevent leakage. Many filters have an anti-drainback valve to prevent dirty oil from backwashing back into the oil pan. They also have a pressure relief or bypass valve that will allow oil to bypass the filter element in the event that it becomes too plugged to pass enough oil. This prevents engine oil starvation and the possibility of destroying the element, possibly causing pieces of it and the junk it filtered to enter the engine. Also, when the oil is cold and very thick, it will tend to bypass the filter through the pressure relief valve because it cannot pass through the element until it thins out somewhat. If it did not do this, the filter element media would tear open.
A good filter has a strong steel can to withstand the high oil pressure (60-80psi when cold), an anti-drainback valve that actually works without creating too much backpressure, a pressure relief valve that doesn't leak, and a strong paper element and cap that can with stand the pressure and flow of oil without falling apart. The element media has to be able to trap small particles, but without restricting the flow too much. Cellulose (paper) media is used on economy filters and works OK. The fibers in the paper acts as a mesh to block particles down to a certain average size, while allowing the oil to pass through. Some manufacturers add other media, such as cotton, to the cellulose to improve its performance. There is synthetic fiber media for the high-end filters that has smaller passages to trap smaller particles, but can pass more fluid through it because it has more of them. There is also media that is a blend of these two. There are also "depth" filters that are usually made of synthetic material that has a passage size gradient to it. In other words, the deeper into the element the oil goes, the smaller the passages get. This way, large particles are trapped in a different spot than small particles, which allows the filter to hold more particles before it "blocks" (becomes too restrictive).
All filters have to undergo SAE (Society of Automotive Engineers) tests to prove that they meet the engine manufacturer's requirements. The SAE J806 test uses a single-pass test, checking for contaminant holding capacity,size of contaminant particles trapped, and ability to maintain clean oil. As an amendment of the J806 test, the multi-pass test also looks for filter life in hours, contaminant capacity in grams, and efficiency based on weight. The efficiency of the filter is determined only by weight through gravimetric measurement of the filtered test liquid. Typical numbers for paper filter elements are 85% (single pass) and 80% (multi-pass). A new test, the SAE J1858, provides both particle counting and gravimetric measurement to measure filter capacity and efficiency. Actual counts of contaminant particles by size are obtained every 10 minutes, both upstream (before the filter) and downstream (after the filter), for evaluation. From this data filtration ratio and efficiency for each contaminant particle size can be determined as well as dust capacity and pressure loss as a function of time. Typical numbers for paper element filters are 40% at 10 microns, 60% at 20 microns, 93% at 30 microns, and 97% at 40 microns.
Recommended Filters
Based on the simple criteria above and the information I gathered in the Oil filter Study, I have found some filters that are readily available and are of good quality in my opinion. I have disassembled many filters and made observations and measurements on them. Sadly, some of the most common and popular filters don't cut it in my book. Those filters are described in the next section. The filter names are also links to the Oil Filter Study page, which gives the intimate details of that filter in the Ford 5.0L V8 version. You will find all the hard data for these filters there. What follows are filters that I recommend in alphabetical order:
AC Delco Duraguard
This filter does not appear to be AC Delco's original design, but it is still pretty good. As far as I can tell, it is no longer available for the Ford 5.0L. It has one of the highest filter element surface areas with fewer, but very deep pleats. It also has strong, metal end caps with a nitrile rubber diaphragm-type anti-drainback valve and steel bypass valve. It is one of the better filters you can get for $3.
I have had some feedback about these filters leaking at the seam between the backplate and the can. Often this was in situations where the engine was modified. Also, during a recent oil change, I found that this filter did not have the best anti-drainback valve. It is better than Fram because I have very little valve train noise at startup (I had a lot with the Fram), but I have not used them since.
AC Delco Ultraguard Gold
This filter appears to be a Champion Labs filter. This is not surprising given that Champion Labs also manufacturers other AC Delco filters for some European vehicles. See the German Oil Filter Study.
Amsoil
No real information yet. I have cut it open and it looks like a very nice filter. The manufacturer appears to be the same as Baldwin. I am not sure they are worth the rather high price (over $10 shipped).
Baldwin
They look like tough filters inside. Similar design to the Hastings and Amsoil. These are the filters I have been using lately.
Bosch
This is yet another Champion Labs filter that is sold at AutoZone. I am not a big fan of Champion filters. They seem flimsy on the inside to me.
Car And Driver
This is a Champion Labs filter that is sold at Target.
Deutsch
This is a Champion Labs filter that is sold at AutoZone.
Fram Tough Guard
Even with all the problems of the other Fram filters, this one is not too bad. It has a heavier filter element with more surface area, a silicone anti-drainback valve, the cheap pressure relief valve, but with a clever integral screen to keep out large particles, and enough inlet holes for good flow. The only other drawback to this filter is that it is capped on each end with cardboard instead of metal. Looking in through the center outlet does not reveal any paper end caps, but they are there. I personally do not use this filter, but the design didn't have enough bad qualities to cause me to tell others to avoid it.
Hard Driver
This is a one of the few oil filters that uses a synthetic filter element. It's has a dual-density layering "depth" filter element. The construction of the filter is what you would expect from a quality filter with steel filter element caps and special epoxy-coated steel mesh retainers to keep the element from flexing. It also has a good flowing, strong steel case and a zinc-coated backplate to prevent pre-installation corrosion. I have disassembled but have not measured this filter. I used these for a few years with no problems until they seemed to go out of business.
Mobil 1
This filter is made by Champion Labs and uses a synthetic fiber element that can filter out very small particles. It is rated by the manufacturer at just under the Purolator Pure One as far as filtering capability, but is still very much above conventional paper filters. It also has a very strong construction to withstand high pressure spikes during start-up. Given the choice between the Purolator Pure One and the Mobil 1 filters, I would choose the Mobil 1 because of the restriction concerns of the Pure One. However, as with all Mobil 1 products, expect to pay 2 - 3 times as much for this filter. I have seen this filter sold at AutoZone and K-mart and used them a few times, but I feel they are not worth the money.
Though I have never had problems, I have received feedback from a few people that these filters may leak at the base. It seems that the seal between the backplate and can may burst under high pressure (at startup). These were on Ford engine applications.
Mopar Filters (various)
These filters are Frams, Purolators, or Wixes. Mopar does not manufacture it's own filters, nor do they require anything special from these manufacturers. Since they basically paint them a different color, stamp them with a Mopar logo, and double the price, there is no reason to buy them. Sadly, the Mopar Severe Duty 53020311 filter is actually the worst filter of them all. It is a Fram Extra Guard.
Motorcraft
The one I opened seemed to be a Purolator hybrid. It had the Premium Plus case (anti-drainback valve, gasket, etc), but with what appeared to be a Pure One filter element. This was a cheap way to get a Purolator Pure One. It is sold at many locations including AutoZone, Pep Boys, etc. I have heard from several people that Motorcraft seems to switch between Purolator and Champion Labs as the manufacturer so be observant.
NAPA
They sell two lines of oil filters: NAPA Silver and NAPA Gold. They are both made by Dana (Wix) and there is no obvious difference between them. They may have different elements, but NAPA does not state that this is the case.
PowerFlo
This is a Purolator Premium Plus that I have seen at Murray's Auto Supplies.
ProLine
This is a Purolator Premium Plus that I have seen at Pep Boys. Pep Boys also sells the Purolator Premium Plus brand, which is pretty dumb (to be selling both).
The Purolator is a solid design. It seems to have one of the tougher paper filter elements of the low-end filters and the bypass valve is built right into the cartridge. There are no internal sealing problems with this filter at all. There is an assembly string that is wrapped around the filter element, probably to hold it in place while the glue cures in the end caps. In the ProLine (one of the Purolator clones), the string was wrapped too tightly and had damaged the filter element. All the other Purolator-made filters (8 in all) had no trouble, and even the damaged one would probably have been fine. I usually go with these in a pinch.
Purolator Pure One
This is an interesting filter design made by Purolator. Most of the construction of the Pure One is the same as the Purolator Premium Plus. The big difference is the filter element itself. It has a dense paper/fiber filter element that can filter very small particles. The result of this is cleaner oil exiting the element, but more oil restriction. Purolator addressed this by adding more filter material (more and deeper pleats). After seeing one of these filters cut open, I am apprehensive about this filter. It seems to have so many pleats that it is almost a solid chunk of filter element. It seems like it would end up restricting the flow, more than anything. Purolator has plenty of data on the filtration abilities of this filter and I don't doubt it, but they have no flow data. Even so, I don't see any major problems with this filter. It also sports a silicone anti-drainback valve and a PTFE treated nitrile rubber gasket.
STP
This is a Champion Labs filter that I have seen at AutoZone and Walmart.
Wix
Another quality oil filter similar in design to the Purolator. It has metal end caps on the filter element, a standard nitrile anti-drainback valve, and a seemingly good flow. They are manufactured by the Dana corporation. These appear to have a depth gradient filter element, which uses cotton fibers to progressively trap smaller particles as they get deeper in the filter. This helps maintain good flow as the filter gets plugged.
Filters To Avoid
The following list of filters have known problems. You will see well-known names here and will probably be disappointed. This is because many of these brands have stopped making their own filters and buy from a common manufacturer.
Fram Extra Guard
Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circulating through my system. The oil passage to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it.
Fram Double Guard
Another bad filter idea brought to you by your friends at Fram. The filter itself is a slightly improved design over the Fram Extra Guard, but still uses the same filter element. It has a silicone anti-drainback valve, a quality pressure relief valve, and enough inlet holes for good flow. The big problem is that they are trying to cash in on the Slick 50 craze. They impregnate the filter element with bits of Teflon like that found in Slick 50. As with Slick 50, Teflon is a solid and does not belong in an engine. It cannot get into the parts of the engine that oil can and therefore does nothing. Also, as the filter gets dirty, it ends up filtering the Teflon right out. Dupont (the manufacturer of Teflon) does not recommend Teflon for use in internal combustion engines. Please do not waste your money on this filter.
Penzoil
This filter is a Fram! It is the exact same design as the Fram Extra Guard filter and it is junk. On the up side, it costs $1 less than the Fram version.
Quaker State
This is another Fram Extra Guard that I have seen at K-mart. It used to be a Purolator, but Quaker State is now owned/controlled by Penzoil...
First, do no harm.
Lot of nice info, thank you. ? I have several car filters that are left over after cars are gone, would it hurt to use them on my toro if they fit on. Am looking for opinion here, i probably will try it anyway. thanks in advance
Yes-you can check , and a lot of times-things do interchange--for instance, my Toyota Tacoma p/up with 3400 V-6 engine uses the same oil filter as my Scotts lawn tractor w/ Kohler engine.... :bannana:
Just check and make sure no rust around top of filter--I have seen 'em sit up and get real rusty...
Member #495
I've switched to Napa filters. Made by Wix I've heard great things about them on this board and they are inexpensive. I have been buying the gold filters, but may go back to regular if I can't find a difference.
"The Lucky Muscle"
Discussion Starter #10
I ended up getting a few purolators. I'll see how they work out. I see that the Motorcraft FL400 is almost a 5in filter (4.8) that has the same specs needed and it about 1.5 longer then the Kohler filter. Would their be a harm using a way longer filter?
I have read alot about this on different websites and other rums for motorcycles. Basicly they say either the wix or the purolator filters are the way to go. This is good news because I have relied on wix (napa) for a long time and have had great results. I have also heard great things about the wal-mart super techs but haven't had any expierence with them.
massey man, i saw that article several years ago somewhere on the 'net. it is indeed very informative. it amazes me how many "mechanics" swear by fram filters. i bought a variety of different brands years ago and cut 'em up and found the motorcraft and the napa filter to be very well constructed. i hope that hasn't changed. napa has a very wide application chart for all uses.
haffast
Thanks for the info. :thThumbsU I just recently purchased some WIX filters oil & Air for my 1020. :bananapow Hope they are OK. I once bought some no name filters on ebay for my 9N. The 9N uses the cartridge type that are hard to find. The no names fell apart in the canister. :ROF I had to dig them out with a screwdriver. :duh: Luckly there was no engine damage. Learned my lesson. Don't save a $ on filters. :Stop:
yes i always used fram,suppose to be so good,heck they where in hot rod magazine and written on all the race cars...it's amazing what good advertising will do.i'm going to use wix,they have a filter for everything,this is one of the good things about this forum you learn what's good and what's not....mm
Just Have a Little Faith!
Does anyone remember back when they had these oil filter canisters that used rolls of toilet paper as a filter element?
"The Lucky Muscle"
Discussion Starter #16 (Edited)
Has anybody used the 4.8in FL400 or equiv? Its the same just longer. They are accually for a 3.8L Mustang motor. Does a long filter hurt the motor in the long run? How big can u go?
Here's a list of Briggs/Kohler filters-
"Briggs type"
3/4" X 16 threads
Gasket 2.734"OD 2.430"ID 0.226" thick
Length inches Wix Purolator Hastings Fram Kohler B&S Baldwin JD TEC MotorCraft
2.3" 57035 NA LF503 NA 2805001 492932 B7165 ? 36563 NA
2.7" 51056 L35310 LF302 PH8172 1205001 492932 B1410 AM125424 36262 NA
3.4" 51348 L10241 LF157 PH7575 5205002 491056 BT223 AM101207 ? FL793
4.8" 51516 L20195 LF134 PH3600 NA NA B243 ? ? FL400
The longer filter shouldn't cause you any problems as long as it doesn't have clearence issues. The longer filter has more filtering media, and will 'soak up' more oil...so make sure if you use the longer/bigger filter, that you have the proper oil level on your dipstick! :thThumbsU
Also, a little FYI: Pour some fresh oil into a new/dry filter, allow it to soak in, and add some more oil before you install the filter on your engine. When an engine starts, it draws oil in from the filter first...if the filter is bone dry, the top end of the engine will run -dry- until the oil is pumped into the filter, and to the top of the engine... This delay in oil flow is hard on the internals!
First, do no harm.
Lilys dad. they still make those tp filters and spinner filters. I dont use them but saw a lot of articles on them in the diesel forum for dodge.
First, do no harm.
Dad the ones i saw pics of are forced on and did not fall apart. They did have fine screen and you use the stuff you can use for note paper.
1 - 20 of 26 Posts
