So up here in NH I got 16-18 inches of heavy wet cement like snow. I got up at 4am and put the X500 to work and it did well moving this mess, better than I expected!
I noticed that the motor did not bog down at all even when under a heavy load. However there was a noticeable noise when I was on level ground moving considerable about of snow. It sounded like crackling noise and was not constant. It was only happening when I was moving forward while blowing.
Not sure if it was from the blower or the tractor. Kind of noise you just don't want to here from a tractor. Almost sounds like gears of some sort grinding and or missing a few teeth.
What do you think gang?
