OK. This is a question that should at the least provide a good laugh to you experienced pros.:sidelaugh I am almost embarrassed to ask it but I have run out of ideas.
I have a 6284 Cub Cadet CUT 4x4 with 28 HP diesel and hydrostatic trans. I recently bought a 3 point box grader to grade my long gravel driveway which has been in need of grooming for a long time. I hooked it up and the first few passes did a nice job of cutting down the raised center of the drive and filling the ruts. That's where everything went south for me.
While I was able to level the drive across the width it was still uneven down the length of the drive. I started working on smoothing the length of the drive and the more I worked the worse it got. My problem is that with the short wheelbase, when the front of the tractor rises on high areas the tractor squats in the rear and the box blade digs in making a low area. After a few passes there is a pattern of hills and valleys that get worse every time I go over it. After several hours of trying everything I can think of I now have a great roller coaster where my driveway used to be.
I have tried a number of things as I will describe here. At first I tried to slightly raise the blade in areas that are low to allow gravel to slip out and fill those areas. The three point just doesn't have a light enough touch to feather the blade height and I either don't raise enough to let gravel feed out or the blade rises rapidly and dumps too much gravel. I tried to use the float setting by running the PTO control all the way down but even at a float setting the box blade digs in until I have so much gravel scoops the tractor starts spins the tires and I'm just digging. I also tried working with the knives installed to try work up loose gravel and let it slip out in a smooth layer. But regardless of what I do when the front tires rise up on high areas the back end immediately squats and digs in exasperating the problem.:duh:
I know someone out there probably can tell me what I am doing wrong (if you can stop laughing long enough). Any suggestions are appreciated. My wife is not impressed with what I have done to our driveway with my new toys and she'll kill me if further attempts result in our van getting hung up on top of one of the hills.:00000060:
HELP!
Jeff
HELP!
Jeff
