If you think *that* is sludged up, you should have seen the rocker arm covers on a '59 Ford T-bird 352. There was so much sludge that the rocker arms weren't visible. They operated inside a block of sludge, with only room for their motion to take place.
One would think that the valley cover inside the spot welded cover needed to be spotless to work, but they seem to get by without, and all the 'stuff' in there would have stayed in place and caused no problem. The T-bird intake had a separator that was riveted to the bottom of the manifold. Exactly under where the exhaust gas crossover was routed, adding heat for smooth operation when the engine was cold, but cooking any and all oil that got trapped in the separator. Not sure what the reasoning was behind putting the separator there...
tom
tom
