Model number, spec number..picture...need more info on this one.
Test fit at a hardware store. 8MM doesn't begin to thread in. Store I was at only fine or coarse, but I don't remember the numbers. 10MM doesn't begin to go in. They didn't have any 9MM if anyone even makes those.How did you determine 8mm was wrong?
Thread gauge lines up best on 20/in, but a 1/4-20 slips through and I couldn't find a 5/16-20 bolt to try.If you have an assortment of bolts, or a tap set, can you see what pitch the thread is?
Possibility, but what would the equivalent be? #10? #12?Machine screw threads?
Saw is a 14in, 35CC Homelite
Stripped nut in question is inside the yellow tensioner just above the '5' in this picture. Tensioner may not be the right term. This turns to hold the bar in place after adjusting the chain tension using the yellow thumbwheel just above the '3' in the picture.
Actually, I got a threaded rod coupler and with the help of a washer, it works quite well. I can get it turned on enough threads to keep it in place and be safe.what would he do with a nut ???
I'm guessing that part has a nut inside and arms are for applying manual torque"Amen" what would he do with a nut ???
W
