"Is there supposed to be power at that wire or is this used to ground out the coil?"
That is the "Kill Wire" and no outside power of any kind should reach it. It shorts the coil to stop the engine. To test your coil, unplug that wire at the coil, IF there is no spark now AND the air gap, space between flywheel and coil laments is correct, then no fire means the coil is bad.
Walt Conner
Walt Conner
