Yesterday was a nice day here--almost 70 degrees and not acloud to be seen,so I decided to clean up the mess I made Monday cutting some trees up for firewood--I left all the logs scattered all over and it got dark WAY too soo to finish the job,plus I was BEAT...
I had planned to clean off a yard trailer I made years ago that I had piled high with junk--it had rotting sheets of OSB and a ton pf plastic sheeting I removed from my former "greenhouse",that alone took a good half an hour..by then it was noontime,and I figured I had better get my SS-12 out of the garage and start it up,as it had not been used since maybe last may..
I back my car outside,moved 2 other Suburbans,and added some gas to the old trusty rusty SS-,pulled the rope many times,got winded,and said to myself "*** you for being a cheap SOB and using that "old" gas I got from a car that was about to be junked months ago"--I had run the tractor out of gas last time I used it,but the tank I had on it,an old Kohler one that was pretty crappy inside with rust still had a good inch of stale gas in it,that was below the fuel outlet...
I soon discovered no fuel was reaching the carb,and I was not unhappy about that,as that meant the carb likely hadn't been "poisoned" by the old gas....after looking in the tank I decided to yank it off,and I found my old fashioned glass bowl filter/sediment bowl shut off contraption was blockes solid with rusty crap right where the 1/8" pipe screwed into it...(I had just "rebuilt" it last winter at the end of the seaon,I was tired of it oozing fuel and making a fire hazard in my garage)...
The more I looked at the old rusted tank,I figured I would be having nothing but grief all winter with it,not something to look forward too when the last thing you want to be doing is fixing a tractor in frigid weather ,instead of being able to USE it and depend on it...I decided a smaller plastic tank would be better,as I never did fill that huge metal one up full ONCE since I had it on there,and nowadays it would take 10 bucks to fill it--I rarely used the tractor long enough to use up even a quart of gas to plow my driveway or walkways,so I looking in my shed and found one off an old blown up Tecumseh walk behind push mower,that had a big plastic "shroud" made onto it...my hack saw trimmed that off quickly!
I had to drill a new hole for the fuel outlet,and another for a mounting bolt,and I used a peice of brake tubing as a spacer between the tank and the mount so I could tighten the bolt good,but not squash the tank--it worked out well...the next dilema was to decide what to now use as a gas filter and shut off valve--I wanted to retain the glass bowl one,but the more I thought about it,the more I feared that glass bowl would shatter in the middle of plowing or way out in the woods,so I decided to put a small clear plastic filter and a shut off valve from the same push mower I got the tank from,the Briggs style with a red knob on it...
Then I realized the tank and hoses have to be higher than the carb bowl so gravity feed will work!...turns out they are real close to the same height,but I got a good flow out of the fuel line..so I put it all together,and to my delight,it fired up on the first pull!..the tank even says "Craftsman" on it,so its still "all Sears!"...
Only bummer was by this time,it was getting DARK already!--I had all of ten minutes to pick up and stack about 100 log peices on that trailer,and I hooked it to the tractor and used low range,the trailer has tires,2 on each side,both front ones were FLAT--but the tractor yanked it away like nothing,even with the flats..I hastily backed it up behind my garage,and scrambled to put away a bunch of tools,get the tractor parked back in the garage,and move the other 2 Suburbans back in place,put my car back inside (and it barely FIT!)....after that I realized I hadn't even had LUNCH yet,andat 5;30 pm,it was dark as midnight already!...did I mention I HATE daylight savings time???...
Now its pouring out,and my logs are soaking wet...just aint enough hours of daylight to get everything done!...oh well,at least maybe my tractor will START next time I go to use it..I HOPE..
