Just thought i would post this for anyone who has had the same problem as i. using cheap 12volt winches and burning up the control. I fixed mine and have gone thru 2 winches and the same control is still working perfect.
Mind you, the "fix" is a little expensive, but... it will last and also seems to give your winch a little more power as it is not being robbed by bad control and small wires.
What i bought was a 12 Volt DC Reversing Solenoid.
The specs are:
Used for permanent magnet motors.
Such as winches,Hoist Any Reversible permanent magnet motor.
No need to use the (4) SPST Relays or the
(2) SPDT Relays with this New Reversing Solenoid .
Voltage: 12V DC.
Max operating voltage 14.5V DC.
DPDT intermittent duty.
Contacts: Copper
Flat Base type bracket Large studs: 5/16" -24
Coil terminals: two blades
Coil type: common ground
Two integral solenoids provide dynamic braking for permanent magnet motors when neither coil is energized.
12V DC 75A make and break,
max On time 5min.
12V DC 125A make and break,
max On time 30sec.
12V DC 150A make and break,
max On time 0.5sec.
Allow 5min Off after max On time. Use with a SPDT momentary toggle or rocker switch:
a momentary rocker/toggle switch can be run almost any place, small and doesnt get in the way.
A momentary switch i used has these specs:
Circuitry: SPDT-Momentary
Electrical Rating: 25A at 12V DC
Contacts:Silver
Housing
lastic with plated steel cap
Up Position:Momentary On
Center Position:Off
Down Position:Momentary On
Terminals 3 screw
You can buy the momentary switch here:
http://www.texasindustrialelectric.com/toggleswitches.asp
part No.55021
the reversing sol. can be found here:
http://www.texasindustrialelectric.com/relays.asp
part No. 24450
attached is a picture of the sol. and a switch
And a word of caution, ALWAYS use a momentary switch, for anyone who doesnt know, momentary means it returns to OFF position when you release the handle of the switch. No matter how careful you are with the type that stays on, it WILL eventually get switched on when you dont know. And bad things happen to electrical devices when they have power, and cannot move, (like a already wound tight, winch)
been there, done that..
You can actually power a front and rear winch from on setup too. I am..
Just wire up both winches to sol exactly the same way. Only one activation switch. But add a cut off switch in one side of the 2 wires wires going to each winch.
Then just always have one flipped ON, while other is OFF. Simple...
The specs are:
Voltage: 12V DC.
Contacts: Copper
max On time 5min.
max On time 30sec.
max On time 0.5sec.
Contacts:Silver
Housing
Center Position:Off
Terminals 3 screw
part No.55021
part No. 24450
