You guys have helped me before so I have complete confidence you will again..
My GT 917.273090 with a Kohler 22HP model CV22S no longer charges the battery,, Here;s what I have done so far according to troubleshooting manual:
AC on connector (disconnected from regulator )reads milli volts with engine running
Ohm'd the stator, across both White leads.. .2 Ohms.. manual says .02 ohms so I think I am probably OK there.
Ohm'd both white leads from stator to ground,, no short to ground: good
The stator is just a simple coil right? Not much to go wrong with them. Is there any diode's or components in the stator?
Thanks much
d
So I am trying to get the bolt out that holds the flywheel.. It's not reverse threads is it?. Whats the best way to hold the flywheel and apply max pressure on the bolt?
Thanks much
d
