Hi All,
I have an '83/'84 JD 317 that I've fixed up a lot. I use it every week year around just about (mowing/snow). I haven't been happy with how it has been cutting grass (uneven, leaving strips between the blades), so have purchased new OEM JD blades. Tonight I worked on the deck for several hours. This tractor has had many previous "fixes" so I can't be sure what is by design and what is a screwup. So, a few silly questions...
1) all 3 blades should be on the same plane (at the same mowing height), right? My center blade (spindle) was about 3/16" lower than the other two.
2) aside from being on the same plane, all blades should be parallel, right? My blade (spindle) furthest from the chute was cocked at an angle.
3) it shouldn't matter how the 3 blades are aligned, right? As they're belt driven I figure they may move some anyway..
I've used washers and such so that all 3 blades are nice an even, at the same height (fixing 1 and 2 above). But now two of the blades touch very lightly and I can't do anything about that unless I want to file down the ends of the blades a hair. It's unlikely that it would ever be a problem but that is why I ask the questions above.
Thanks!
Tommy
Thanks!
Tommy
