I got tired to put on and back this heavy snowchain on my HT 23.
I think it will go faster if i have 2 wheels to change between.
A trip to the junk yard and I found 2 wheels from an Chevy, 225/75-15.
Power up the plasma and I have beginning the converting to Bolens.
Here it will be a picture but i cant upload it
The 1256 I am working on now came with two donut spares bolted backwards to brake drums that were bolted to the hubs. Crude but effective. Made me think about making some weights out of some heavy rotors I have laying around.
If you didn't want to do all that rims with that bolt pattern are easy to find and if you want to go faster you can get a set of 20" ones off an old Deere combine,might have to do a little fender alteration.
Just a word of advice--you should never weld on a wheel with the tire still mounted--there was a man in my hometown who was DECAPITATED when the wheel he was welding on exploded. Turns out there was some Fix a Flat in the tire and it is Very flamable, plus was under pressure creating the perfect bomb.
Painted with Hammerite silver.
New chains. They are not in correct size so I have to extend them.
The tree extra holes are for bolts. I will make some weights in the future
and also fill them with water.
Looks very good! You were lucky welding on the Rims with the tires still on.
Check out this link for welding on a Rim with Tire on it and what could happen.:fing32: http://www.youtube.com/watch?v=uScd7nFzfQE
I have never thought of that.
But what you not see was that I have let the pressure out. And that just becuse I will fill them with liquid after I have weld them. If not, it maybe could happens.
I have filled the wheels with water and antifreeze liquid, so the weight are about the same as original wheels + wheelweights.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
