I just bought my first tractor this past weekend, Farmall H. I'm going to be using the tractor just for fun, I will be entering the tractor pulls in my town this year.
My question for some of you pro's out there is - I am leaking oil pretty good out of my "belly pump"???? I believe that is what it is called. To my understanding there are three places on this tractor that hold fluid - the engine - the rear end- and the hydraulic pump. If I do not have a use for that pump can I just let it run out of oil? That way it stops spitting oil out by the quart onto my shop floor.
My next question is that I am not turning as many RPM's as my buddies 2 H's are (they smoke me in road gear), what can I do inside the governor to get more RPM's out of the motor. My throttle linkage is opening it up all the way until it hit's the stop, so I figure the problem has to be inside the governor itself.
Thanks in advance for the help.
