I would think that it will work just fine. If the discharge size is the same mount it up and go. I don't know if there are a "bigger" power head for bigger decks but going to a 48 from a 46 there should not be a problem.
As long as you are having to look, maybe consider a Cyclone Rake. It will offset the cost of the PowerFlow unit and remove the extra weight on the discharge side of the deck and I feel get a better unit, since it holds a lot more and can dump if you have a ravine or hole you want to fill. I bought a Cyclone Rake that was initially used on a Kubota Zero Turn. I made it fit my Scotts L17.542, 42” deck, then modified it to fit my X738 with 54” deck. I skipped attaching it to the X360, 48” deck, since it had the mulching kit installed. I used it for just mowing. The X738 is used for mowing, leaf pickup, spreading fertilizer/lime, snow blowing, and occasionally use the blade to level leaf piles or gravel on my son’s driveway.After spending some time today trying to get the power flow attached I realized it just isn't going to fit. And after speaking with a John Deere Service Tech he advised me of the same thing. The power flow 48 will not match up to the 54 inch Edge Deck. He advised that I need the power flow for the 54 in deck and there really is no other way around it. He advises that the chutes and bagger will work, it's just the power flow unit that will not. They are about $600. new so I guess I'm onto plan B for now. I will keep watch for a used one down the road.
Thanks to all of your comments and assistance. Greatly appreciated.
When you say it isn’t going to fit, what is different other than the belt length? Deck depth would be the other thing I would expect to cause an issue.After spending some time today trying to get the power flow attached I realized it just isn't going to fit. And after speaking with a John Deere Service Tech he advised me of the same thing. The power flow 48 will not match up to the 54 inch Edge Deck. He advised that I need the power flow for the 54 in deck and there really is no other way around it. He advises that the chutes and bagger will work, it's just the power flow unit that will not. They are about $600. new so I guess I'm onto plan B for now. I will keep watch for a used one down the road.
It all depends on what comes up first. A lot of the used PowerFlow units get sold with the tractor or once in a while with a deck.
The housing doesn't go all the way into the deck discharge opening. The small rod that's on the left of the unit is supposed to go into the wheel housing block and its about 3 to 4 inches short of hitting the hole. I even tried taking the grass flap off to see if that would help, but it didn't. Even though the deck is bigger I would guess that the housing for the power flow 54 inch is not as deep. My plan B is when leaf time comes I am just going to mount my deck from the 48" and mount the power flow on that and use the 48 for cleanup. That worked great previous years on my x360 so should be ok on the 530.When you say it isn’t going to fit, what is different other than the belt length? Deck depth would be the other thing I would expect to cause an issue.
If you look at a parts breakdown, $600 isn't to bad. The housing of mine wore through on the bottom, and I looked into replacing just the housing (after repairing it for several seasons). It was only $150 more to get the entire Powerflow head with turbine, pulleys, belt and mounting bar. It would have cost almost $875 to have bought those separately.….. the power flow unit that will not. They are about $600.
Something I have seen, but can’t remember where, was where a user put boxes inside the lawn-vac. If you had some the right size, maybe you could slide the leaf bag over them, then turn them upside down to empty into the bag. Plastic waste basket would be about the right size. It would be even better if you had a frame to hold the bag upright and just fill them while sitting in the Cyclone Rake. Then just drive to the curb, slide the bags out, and leave them at the curb. Surprisingly, the Cyclone Rake packs material tighter than you can pack leaves in a bag. I understand the hassle. I mow a widow’s trailer park lot with a push mower with a bagger. Always a pain to dump the clippings into a bag. Come Fall it will be an even bigger task and I’ll have to figure out the same issue.Early on I looked at those before I got the Power flow. Problem is I have no place to dump, short of loading everything on my utility trailer and hauling if off to the dump, or I can put the leaves and clippings into garbage cans and let the town pick them up once a week. I have done both, but its always 16 or so garbage cans out to the curb. Gets old in a hurry. A least the power flow grinds them down and I can load them up easier without as many cans if I put them out and less bulk if I haul them away. Doesn't seem like there would be a easy way to unload the cyclone rake and then reload to the utility trailer.
Good though, Thanks
