Hello Everyone! I have recently received a MTD Mastercut rider
Model # 13AJ775G059
Serial # 1C038B40280
Long story short, my neighbor had this rider for a very short time and says that he installed a trailer ball to it and after that was never able to get it running... He asked if i wanted it and clearly couldn't resist! The thing is still like new! Except! for the wiring mess I inherited... There was no positive battery cable and the in-line fuse was missing.. I went to the local hardware store, bought an in-line fuse kit, 20amp fuses and made a new positive cable. My problem now is, every time I try to hook up the positive cable to the battery, I blow the in-line fuse. I have checked all safety switches, and even tried disconnecting everything but the ignition switch, still blew the fuse. Once I disconnected the ignition switch I was able to connect the battery without the fuse popping! But as soon as i tried to connect it, Poof! It blows.... I have an older MTD lawn machines and removed the ignition switch from that and tried it and was able the connect the battery, and the switch! But as soon as i tried to turn the key...Pop! goes the fuse.... Ugh... I am thinking towards ordering a complete new wiring harness and starting from there...? I have attached some photos and will post more if needed... I do want to add that I was able to jump the solenoid and the engine does turn over!
Thanks for the the help!
Model # 13AJ775G059
