New (to me) LB with BBC questions
485 Views 3 Replies 2 Participants Last post by  XR55
I picked up two more LBs the other day, a 7261 and a 8244 SUPREME.
The 8244 started after cleaning the carb but only sputtered. Pulling the cord with the bladed engaged finally got the mower running. at a normal speed. At idle it was surging.
Any tips on how to pull the muffler to check the ports? I am worried about $50 worth of gaskets. And if the seal is bad, do you pull the BBC assembly? Anybody been here, done that?
Thanks.
Hi Mark, it is easy to do. Remove the blade by removing two 9/16 head bolts holding blade to BBC. Then remove three 1/2 head bolts holding muffler to motor base plate. If the O-ring gasket is in bad shape, go to hardware store and purchase the same size rubber o-ring.
I pulled the muffler cover and gaskets and cleaned what I could. The gaskets had 1/8" of carbon caked in place. I left it alone for fear of damaging the gaskets.
I saw no sign of a leaking seal, but you would need to remove the BBC to replace it, correct?
The drive mechanism was missing a bolt. Does anyone know the exact dimensions of part number 602984?
Thanks.
To replace the lower crank seal you would need to remove the BBC. To replace the o-ring between the muffler housing and the motor base plate, the BBC doesn't need to be removed. I didn't know which seal you needed info. on placing.
