As far as the tractor itself, I can help you out with a lube chart attached below. Click on it a couple of time to enlarge it. Right click on the picture, and hit print, it should print out a full sized copy, on printer paper. Shows capacities at the bottom of the page. Arrows point to drain/fill locations, and others to locations of zerk fittings.
As far as the hoe & loader, those resemble Hough Wain Roy units. Guessing the loader operates off a front mounted pump, and the uprights the loader arms attach to in the reservoir for it. Possibly a hose linking the two together(??) so both side hold oil. And assuming the hoe uses that same pump & reservoir. Guessing a 303 oil (20 wt) would work. Somewhere in the system should be an inline filter. You'll probably have to get the filter out, and look for the part number.
