So today I picked up a tractor from a fellow on the eastern shore. He did not know anything about it. It was his grandfathers and has not been run in several years. Looking it over, I new if it was a problem, I could part it out :Stop:
Anyway got it home, locked up tight. Poured some MMO in the cylinders. Took the shroud off and found the starter was jammed. Freed it up, hit the key and sprayed oil over everything in the shop! Anyhow, got that cleaned up. got it to run on carb spray. It has really old gas in it. Figured I need a carb kit. Then I saw the label on the shroud. Kohler M20 Magnum! Sooo, it's a repowered tractor? I don't know but I guess so. Anyone know the number on the carb kit?
