more pics
Being as that there's no hydro or belts to slip since the PTO shaft is a direct drive from the engine output gear, your likely getting close to, if not the full, 20hp.got the wiring sorted out and this weekend going to open up the trans case to find where 2nd and 4th are hiding. i mowed a little with it and was suprised by the power this thing puts out. i wonder if there is any way of knowing how much hp goes to the pto for the deck drive system? and can anyone tell me what year this tractor is?
Its the bolt comeing off the axle block. Thats what controls the lock into forward. Kinda sounds maybe to tight. Hard to say with out being there thoughgot a slight issue, my forward lock doesnt stay locked on the pedal. it goes great in forward or reverse and i set the clutches as per the directions on the forum. if i got the adjustment too tight could that be my culprit? there is not backward or forward creep like it is way overtightened. it will even stay locked for a little bit then its like it works its way out.
