New tires on b10
3101 Views 6 Replies 4 Participants Last post by  Hdpearson13
Has anyone used Titan r4 industrial tires on there garden tractors. I have an opportunity to get some for under 4O bucks. I guess there front tires for larger tractors but look like they will work good. They are 23/8.5-12s
Thanks again. I am just using them to doze some and fill some land out back i think they'll work but have no experience with at tires
1 - 7 of 7 Posts
Do you know what tread design they are? I don't see why they wouldn't fit, but they would be awful firm. I'mthinking R-4's are like a skidsteer tire, right?
http://www.titantirestore.com/industrial_tires.html
I personally like the front atv tires. Kenda Bear Claw ATV Tire 25-8-12.
I use these to pull a one bottom plow or a mini two bottom plow. Great for breaking grass.
You can find my plow at http://www.quadivator.com/UTVplow.html I've had it pull hard enough in really hard soil to put the legacy in low range and honda engine poof out smoke rings. Typical soil it maybe pull a little harder then a one bottom but not by much. Can pull it in high range normally. Last year though was a odd year for MN the ground was super dry and fields were cracking. Some of the farmers had two 8 wheel tractors chained together with a chisel plow just to break ground, Both 8 wheelers were smoking pretty good!
From what I googled, they are a CUT tire factory used on Deere & Cubs to name 2., probably fronts in that size but they do have a bar type tread and aren't loader tires. Sounds like they did have a batch made that don't hold up well, weather cracking bad before their time. Still, that is a good price.
Accually just bought some nice Titan ag tires used off Craigslist this morning I don't have the type name but put them on the 6216 rims I have that are 10.50 x12 and put the on b 10 and was lucky enoughy to get 3 inches of snow today. They worked great not as good as my chains but easier on driveway. I would really like wheel weights. Now I just need the ribbed front tires also. I have a set of almost brand new Deere rims that came with tires but offsets wrong, hopefully I can trade them for some ribbed front tires or weights. Don't know if I'll still get r 4 for I would have about an hours drive and go back tp work tommorow for next cycle and that means 15 hour days for 6 days.Thanks for everyone's input
1 - 7 of 7 Posts
