I wouldn't be to concerned, but smarter guys than me will be along shortly.
I don't know hardly any environment it could be stored in where pretty much everything rubber would be trashed after only three years. For that matter, has anyone ever replaced their tires after only three years where the tractor was being used and they were trashed during that time?For the very risk averse...
If it was stored in a dry environment budget for replacing pretty much everything rubber (belts, exposed seals, potentially tires, etc.) If it's still a good good deal, then go for it.
It's not so much from the heat/time as the lack of use.I don't know hardly any environment it could be stored in where pretty much everything rubber would be trashed after only three years. For that matter, has anyone ever replaced their tires after only three years where the tractor was being used and they were trashed during that time?
Regards,
Rich
Link to thread please?This isn't like the 30 year old JD 318 still in the crate which we've seen recently.
I don't entirely agree, non-use isn't all that bad if stored properly (tires last longer deflated and stored away from ozone and ultraviolet rays). Rubber deteriorates either way, whether in use or not, as an inflated tire forces oxygen through the rubber plies breaking down the bonding between layers as well as putting the rubber at greater risk to ozone.It's not so much from the heat/time as the lack of use.
Whenever tires crack its because they havent been used or sat for a while and the oils in the rubber leech inward causing the drying and cracking. When used, the copounds stay 'moistureized' so to speak. This is very common to see with used tires that have been driven on vs. those the same age that sit in a warehouse. Same goes for seals. Use it or lose it!
And that was my point, I can't think of a three-year scenario that would result in the seals being shot, let alone the tires.I do agree, however that 3 years isn't likely long enough for this to happen. As I said, for the very risk averse is it is extremely unlikely that there will be problems.
