1 - 6 of 6 Posts
Sears Item# 07128985000 Model# 107.28985
Product Description
The Craftsman Professional Garden Tractor features the very best that Craftsman has to offer. The 30 HP Briggs & Stratton Professional Series engine™ with Electronic Fuel Management delivers consistent automotive style starting with no choking required. It has a large 54" heavy duty steel cutting deck with electric height of cut adjustment, power steering with 18" steering radius, cruise control and hydrostatic transmission to make quick work of your mowing needs. The hydraulic lift lever, 24" rear tires and premium transmission with differential lock make this tractor perfect for all your yard and garden duties.
* Briggs & Stratton 30 Gross HP Professional Series™ OHV engine*
* 54" heavy duty steel deck with 3 blades and 4 anti -scalping wheels
* Foot controlled hydrostatic transmission with rear wheel differential lock
* Dual speed control - use either the foot or fender mounted controls to select your forward speed.
* Advanced traction control - power is continuously supplied to both wheels
* Power steering and cruise control
* Electric push button height of cut adjustment - select from an infinite cutting height 1" -3.75"
* Electric dashboard display: fuel and battery levels, hour meter change oil and low oil pressure indicator and a clock.
* Electric PTO engagement
* Pivoting cast iron front axle
* 18" turning radius
* Padded adjustable steering wheel and adjustable seat.
* DC outlet and cup holder
* *all power levels stated gross HP per SAE J1940 by Briggs & Stratton
* Weight: 916 lbs.
* Color: Black/Gold
http://www.managemylife.com/mmh/lis_pdf/OWNM/1008053L.pdf
No idea who makes this one... looks like a new "vendor" code - 107
Has a K71e Hydro Transmission with an external transmission Oil Expansion Chamber.
Upon further research (cross referencing part numbers from the Sears PartsDirect site), this one seems to be a Simplicity Prestige, 2WD version.
http://www.simplicitymfg.com/products/yard-and-garden-tractors/prestige/
http://www.simplicitymfg.com/products/yard-and-garden-tractors/prestige/specs/index.cfm
The Magnificent
There are threads in the Simplicity, Craftsman, and BYRT forums on this one. Our local Sears has one, and I scoped it out. Pretty darn nice!
The transmission in these are made by tough torq. The same transmission in the John Deere X500 series. Very good unit.
Isn't it amazing how that slope 'spec' is the same in every Sears tractor?
I'd love to make one of those safety lawyers spec out a military vehicle. The Humvee, able to scale a 10 degree slope, able to traverse 10 centimeters of water. Travel off road, up to 10 miles an hour...
1 - 6 of 6 Posts
