1 - 18 of 18 Posts
New owner of a much in need of repairs Bolens HT20! Ill will have many questions and needs for reources and I am hoping this forum can help!
Jeremy
Welcome to MTF. This forum will definitely be able to help you out. :wwp: of your tractor!
Jason
Welcome! Nice to see another large frame guy.
Welcome to MTF we like pics
:MTF_wel::wwp:
Eleven Year Site Sponsor
:Welcome1: Always great to have another Bolens owner on here! Whereabouts in Maine? I grew up in Hampden, next down the river from Bangor.
Always nice to see another Mainer! I live in Oakland about 50 min south of Bangor. I am hoping to find parts suppliers for this tractor because its really a nice one, just been a bit neglected:(
My grandparents had a summer place over on Cape Rosier, my sister did summer waitress work at the Oakland House, and I still have an aunt living in So. Brooksville. Small world.
Bolens 1886-01
Welcome to the forum. It's nice to see another large frame person here. I'm in Southern NH about 30 minutes from South Berwick.
Newer HT20 owner as well looking for other 54" deck folks that would be willing to help define some dimensions in the deck idler system....
Got an HT20 with 54" mower (18071). Had an idler pulley go out (top in pic below) and found I have a mess with joint where of the pulley supporting the dual idler (bottom pulley in pic below).
It appears I do not have original hardware (spacers and bushings) which is cocking the assembly so my new idler is sure to fail again unless I find some corrective parts. Problem is I am not sure what is original and what was put together to get it to 'kind of work' up to this point?
I sent some emails based on the parts supplier thread but I can't get dimensions and information to verify what parts I need to order and what I have....
Concern is what do these look like (pic and critical dimensions)
171-8651 spacer
(found website calling for dia 0.625 x height 0.39 x thick 0.2)
This matches my setup on the top pulley 'item 9'
171-4299 bushing (nylon?) - (H, small dia, large dia, internally steel?)
I know i don't have these....
172-2884 spacer - (H, small dia, large dia)
I have something similar (h = 0.93", small dia .625, large dia 1", small dia height 0.51", large diameter height 0.41", ID 0.37")
I believe the idler arms (top and bottom) are original but not completely sure... really only need dimension on large hole on upper and lower brackets. Mine both measure ID at ~0.687 or 11/16" diameter.
No pics now but referencing a mower deck diagram 18071-01-02.pdf from sonnybolens webpage as below - it is the closest to what I have....
:thanku:
Welcome. There is a right and wrong side to put those idlers. I rebuilt a 54" deck at the beginning of this summer. All new spindles, bearing and guide wheel axles.Still waiting on a set if Gator blades for it. I took apart a 48 inch deck to rebuild but after finding that the pan was so bad I declined to do it. I will look to see if the parts you are looking for are there and can be measured.
Location on the deck I am good with, just having the proper components and identifying original parts versus 'makedo' parts in the "bottom" exploded pulley view is really the concern...
Bolens G16YT aka 2016G
This list of Old Bolens Parts Suppliers, (org posted by: AEGT5000) has helped me obtain parts I did not think I'd ever find...:thThumbsU
Hope it helps...:fing32:
I sent some emails based on the parts supplier thread....
So I have tried that but most are willing to sell parts and not so much able to help me diagnose correct versus 'makedo' parts. I need to figure this out before ordering. I have inqiuries to Sam's, Sonny's and Ricks as those stuck out as best possibilities.
Does anyone have a HT20 with 18070, 18071 deck? I know the 18070 is a little different but just wondering if there is a problem with the nylon bushings?
Thanks in advance for anyone that can help....
Sorry there are none of the pieces in question that I can measure on the 48" deck.
1 - 18 of 18 Posts
