1 - 10 of 10 Posts
Hello,
My Name is Bob and I live in Texas. Just got a Ford 9N to do some field mowing. I changed the hydraulic fluid because it was thick and milky, water contaminated due to shift boot torn. Lift was lifting ok before the change but now will barely lift the mower. it will lift very slowly at high rpm. lift leaked down after about a minute before and after the change. Can anyone help Possible problem?
There-in lays the problem, since it was already leaking down slowly you need the heavier weight oil which really should be used in the warmer climates unless you have a super tight hydraulic system. Oh and welcome to the site.
Howdy Bob!
1 - 10 of 10 Posts
