new member
1043 Views 6 Replies 6 Participants Last post by  jdeere
i'm from ohio and own a 2305 jd I joined so I can figure out my problem with my flashers and turn signaals.
1 - 7 of 7 Posts
Glad you joined!
:wwp: If you need easy Picture help
Be sure to Register for Your State!
:MTF_wel: and try the search. Someone else recently was having the same problem. slkpk
Welcome to the forum! :Welcome1: What exactly is the issue with your turn signals and flashers?
Welcome aboard MTF jdeere.:MTF_wel:
If your problem is like mine, its water!
when it rains or I wash my 2210, the flashers flash all the time till the switch dry's out. witch take's a couple days after the water gets in it.
Thats the only problem I have encountered.
Welcome to the forum. Seems last guy that had a problem with his turned out to be one of the diodes had burned out. Common problem on the 2305 I guess.
Everything works when I turn the flashers on except the flasher bulb doe not blink, checked bulb okay. I have heard that there is a diode that supplies power to bulb, but also there is 3 of them, wondering if anyone knows which one of the 3 is part of the flasher system.
1 - 7 of 7 Posts
