No doubt!u might find u want more tractor lol they are addicting
yea and so is MTFu might find u want more tractor lol they are addicting
yea and so is MTF
nice looking craftsman, take good care of it
btw jay :MTF_wel2:
Yes, that is part of the reason I joined MTF. I'm starting to look at chains/weights. I'd like to avoid chains, but as you've seen in my photos, there is a slope and I don't think I'll be able to avoid it. Unless I can since I have a thrower, and not a plow? Thoughts?With the slope in your driveway, now would be a good time to find chains for the tires, and check the owners manual for the maximum amount of weight recommended for the rear end. Most likely it would be 40 pound wheel weights. Filling the tires with the fluid is another option, that is cheap and highly effective.
Yep - had to get a whole pile of maintenance toysLots of new toys in the garage!I have a red tractor also.It's a 77 model.Hope yours last as long as mine!
Here is a thread on loading tires I just finished reading http://www.mytractorforum.com/showthread.php?p=1881882#post1881882Yes, that is part of the reason I joined MTF. I'm starting to look at chains/weights. I'd like to avoid chains, but as you've seen in my photos, there is a slope and I don't think I'll be able to avoid it. Unless I can since I have a thrower, and not a plow? Thoughts?
Also, how does one put fluid in a tire? Does it ruin the tire? Does one drain it in the spring? I may have to find a video for that... I may go that route.
Cool Jim & thanks for the link.Jay, congrats on the new ride and attachments, looks great :fing32:.
You don't have to remove the fluid in the tires once you fill them, my dealer loaded mine up 8 years ago when I purchased and no problems as yet. Here's a great video from member stladrill on filling tires with fluid http://www.youtube.com/watch?v=Toe8ifXX418 :rauch10:.
Where in MN are you? I'm NW of the Metro, halfway up to St. Cloud. (N of Elk River) We're real dry here, and have been for awhile. If it doesn't rain in the next week, I won't have to mow again. I don't have any sizeable leafed trees close to me, (they are all pine trees) so bagging isn't an issue. I plan on putting the blower on the JD soon, but I should mention that I have multiple tractors, so its not like I'm going to have to put the deck back on. I wouldn't worry about the snowblower until the end of October. But the rear weight situation would be nice to get out of the way. WW fluid is cheap, easy to clean up, non-corrosive, and works just as well as anything.I'd like to avoid chains, but as you've seen in my photos, there is a slope and I don't think I'll be able to avoid it. Thoughts?
You will almost certainly need them with that slope. Wheel weights (25 pound ones) are a good idea along with the fluid.
The fluid (RV antifreeze or Windshield Washer fluid) will not harm the rim or tire. You will not have to drain it, the benefit of weight on the rear tires is something you want year around. Do a search on 'loading tires' in the Google search box above to find lots of threads on the subject.
My other question is, do wheel weights cause damage to the tranny?
Actually, I believe they may shorten the life of the hydro if left on year around. I don't think they are near as harmful when used in the winter, when operating temps inside that tranny never reach summer operating temps.
Lastly, when do you usually take your mowing deck off, Cat? I'm thinking I might have one more mow in about a week, but the grass is growing very slowly at this point.
:thanku:Where in MN are you? I'm NW of the Metro, halfway up to St. Cloud. (N of Elk River) We're real dry here, and have been for awhile. If it doesn't rain in the next week, I won't have to mow again. I don't have any sizeable leafed trees close to me, (they are all pine trees) so bagging isn't an issue. I plan on putting the blower on the JD soon, but I should mention that I have multiple tractors, so its not like I'm going to have to put the deck back on. I wouldn't worry about the snowblower until the end of October. But the rear weight situation would be nice to get out of the way. WW fluid is cheap, easy to clean up, non-corrosive, and works just as well as anything.
It is recommended to fill the tire no more than 75% with fluid.I'll only get about 60-70% fill. Is it common to take the tire off and lay it on its side to try to get more in?
