New Holland TC 30 issues- need help
11394 Views 5 Replies 5 Participants Last post by  Rayata Ranch
Hey there, I have a New Holland TC 30 2003. Works Great until I put it in gear or take the brake off- as soon as I do this the tractor cuts off. Any suggestions?
I have had it serviced twice- they replaced plugs/wires thinking it was shorting out.
NOTE: Sometimes it works for 2 days then BAM it starts the "cutting off process"- sometimes 2 weeks, but it always goes back to the same cutting off when put in gear or the brake is released. Any help would be greatly appreciated.:
1 - 6 of 6 Posts
What do you mean when you say the plugs and wires? As that is a diesel. Maybe connectors and wiring for the safety switches?
It sounds like the seat switch is causing the problem as most interlock systems require a the seat switch to be engaged in order for the motion control and probably the parking brake to be activated/ released.
:ditto::ditto:
Thank you for the replies. I will check the seat switch and see if that helps. {Yes you were correct- connectors and wires. }
Friend of mine had the same issue with his 2005 TC30. Turned out to be one of the relays mounted under the left-rear fender (as you are sitting on the tractor). His has three, mine has two, both are in the Safety Controller circuit and associated with various safety interlocks and 'features'.
1 - 6 of 6 Posts
