1 - 11 of 11 Posts
Hi All,
I ordered Gator G5s for my 318 50" deck. I received the blades yesterday, and I had a question about sharpness. I expected more of a sharp blade edge, but it looked and felt rounded and dull. I see there is a clear-coat on the blades which may be contributing, but you can see that the metal itself has some thickness at the blade edge - it does not come to a sharp edge. I attached a picture with a penny against the blade edge to show thickness. If a penny is 1.5mm thick, then it looks like the blade edge is around 1mm thick at the cutting edge.
Question is: Is this normal? This is the first blade set I've ever bought, so I don't have a reference. I was expecting a sharp edge.
I had to sharpen mine due to poor cut right out of the box and after looking around it seems most people have to do the same.
· Super Moderator
Whipper snippers use line up to 0.110" in diameter and seem to cut grass just fine, and they don't turn anywhere near the 190 mph of a lawn mower blade's tip.
Sharpen and hone your blade to a razor's edge and cut your grass once. You'll find that you're right back to square one. A high lift blade lifts abrasive dirt as well as grass. The outer wings on my Gators get worn off after 2 seasons from the dirt sand blasting them.
Funny thing is, there is not a noticeable increase in vibration when only one of those wings is gone. So much for precisely balancing a mower blade. :dunno:
I agree but I was getting frayed brown tips on the cut blades of grass then after I sharpened the new blades nice clean cuts. Just my experience :dunno:
· Tractor Nerd
I use G6, But over the years I have learned that. A mower blade sharpened like a axe will have a good and long lasting cut. Especially if you hit things like sticks. Razor sharp blades for me, are round and dull after one mowing. They aren't worth a hoot for a second mow. So a sharp blade is good, but not a really good sharp blade. You do not want a knife edge on it, unless you sharpen blades every 3 hours.
I agree, there is a utility blade and a razor blade. Both can dull, but if the razor blades hit something, they will bend instead of slowly dulling, which will make a far worse cut. Blades should have a semi-sharp feel to them, similar to a standard table knife blade. It shouldn't feel like a filet knife, that's too sharp.
Discussion Starter · #8 ·
Thanks for all the great replies! I actually emailed Oregon to ask the same question. They said their spec is a 0.030 flat edge for the reason many of you have pointed out - a knife edge does not hold up to grass cutting. (Apparently a .030" does.)
I searched and found some older forums noting the same thing - no knife edge on mower blades. So let it be written,so let it be done.
I thought it says right in the manual not to put a sharp edge on your blades. I always sharpen with a angle grinder and then take a file and remove the sharp edge. I sharpen them once in the summer and once when I put it away for the winter.
· Got Grass?
I just ordered a yellow hornet blade sharpener today, I will let you guys know how it does.
1 - 11 of 11 Posts
