1 - 8 of 8 Posts
Unlike the guys who seem to find these for $300 I had to look at 3 to get what I wanted. The 1st 2 were junk which required a lot of replacement parts like hoods and grills.
The one I picked up today is at least an 8/10, better than my current G4200. 48 " deck and it mows like a dream. More importantly it is quieter and vibrates less.
One question :
My 4200 will drop to about 500 rpm and just sit there and "putt" when you pull the throttle down.
The 5200 doesn't like to go below about 1000 rpm and if you lower the throttle more it shakes and shudders terribly.
Do I need to adjust the throttle a little higher ? If so is there an easy way to do this or directions somewhere ?
TIA
Bobb
I changed both fuel filters with no effect.
I have been using it and the idle seems to be getting smoother so I suspect old fuel and lack of use.
I have been running diesel cleaner/cetane booster through in the fuel.
Bobb
1 - 8 of 8 Posts
