I've got a cc1641 that starts fine (after fill carb bowl with gas) but stalls after running smoothly for about 45 seconds. I've been working on this for about 3 weeks and definitely need help.
Problem started about 3 weeks ago when I found carburetor gunked up with
a brown sugar like residue (left gas in it for about 2 months). I cleaned all of that out, cleaned carb really good with carb cleaner, drained old gas, installed new fuel filter, replaced fuel lines from new filter all the way up to carb. Now after putting in new fuel pump, the problem
still exists. It seems like the fuel pump is not getting gas to the carb.
I checked the pulse input line to the fuel pump - I held a small piece of paper next to it while cranking the engine - it deflected and fluttered like it was getting hit by pulses of air.
I've used fresh gas thru all of this. I've pulled the fuel line off to the fuel pump and held it down below the gas tank - gas flows freely into a container.
I'm at my wits end with this and would appreciate help from anyone.
Thanks,
Pat
Thanks,
Pat
