1 - 20 of 21 Posts
New from Eastern Pa.
So this is my old 68 Sears 10xl which is for sale since I just picked up this JD 210..
Now the JD also has a plow but not sure that I have everything for the plow? I believe you hook up the mower deck lifting lever to it but does someone have any pictures or is there a kit to make it work?
Certified Master Tinkerer
The plow connects to the front lift arm linkage. The "correct" way is to use a lift link which is two short (~2") pieces of flat stock with holes and two connecting pins. If you adjust the lift arm its maximum length you can operate the plow without the lift link.
USMC
Nice looking tractors. slkpk
I'm sorry, but I would keep that Sears. What a slick looking tractor! Look under the front grill on the left hand side of the tractor (left side from a sitting position). You should see a metal plate with holes drilled in it attached to a lift rod that goes back to the rock shaft. The blade lift attaches to the bottom hole of the metal plate with the two little lift links that Deere charges 6$ a piece for. Here's the tractor lift assembly:
And here's the blade lift part:
Welcome to the Forum:MTF_wel:
Check out This web site http://weekendfreedommachines.org/ under Galleries look up Kent Ortmans Gallery He has Instalation manulas for 200 series Attachment's I belive He has the Deere manual for the dozer Blade for your 200 series Model Number 43 Blade.:thThumbsU
Discussion Starter #11
Tried messing with this today but I don't get it. When moving the handle back & forth it seems as though you would attatch to that part under the tractor and would need a long peice to extend out to the angle part on the plow that you have in the 2nd pic.
Couldnt find the correct manual on that site.
Proud JD Owner
Man, that JD looks tough with those big meats on the back! Schu-weeeet!
Nice looking machine, you are in Bethlehem? Im just right down the street from ya in Allentown. Got here Tuesday night for some training over in Schnecksville, leaving Friday morning though. Too cold up here for me. Anyway, good looking 210.
Take your deck off and look under the tractor. If you got the plow with the tractor chances are the PO had the lift kit installed. The one pic shows it clearly. If you have the lift kit installed then you will need a short (2 1/2 inch) link that looks like the link in a bicycle chain only larger. This can be made out of flat stock with a couple of pins. One end goes around the bottom of the lever and pins and the other goes over the arm on the blade and pins!
Have Dog - Will Travel
Hey PA318, cool idea to lay your tractor over on its side to get good pictures of the underside. :thThumbsU
Do you have a source for similar pics of other models?
I just installed one of those on my 110 the other day. Got my blower put back on and wouldnt you know it it's not adjusted long enuff so the blower will not lower all the way to the ground. So I have to take it off and screw out the clevis on the end.
3K & Yet So Little to Say
That 210 looks sweet with the HDAP tires!:fing32:
1 - 20 of 21 Posts
