Hi Guys, here's a stumper for ya.
I have a Murray rider 38inch 11hp engine that I have replaced the motor on. The 11 conked out on me last fall and I found a 14.5 twin to put in it. So far so good. I have had it running too and it's nice and smooth. I had put the mower up on ramps so I could hook up the drive belt after replacing a pulley and left it overnight. When I looked at it the next day I began to wonder where most of the gas went from the tank. Apparently when the mower was tipped to one side (about 45 degrees) the gas drained through the carb and into the oil reservoir.
This engine has a fuel pump and I believe the other was just a gravity feed.
My question is, do I need to do anything special with this new engine or just not lean it over again?
Also, I have drained the oil/gas completely and pulled the spark plugs hoping the gas/oil mix will evaporate. Do I need to worry about anything regarding that mess?
Thanks for any input!
