1 - 3 of 3 Posts
Got 3 new Oregon chains and 3 rim sprockets for the Stihl 026. Several of my old chains are down to there last sharpening so they will be retired. The old rim sprocket shows a lot of wear and should have been replaced last year.
  • Like
Reactions: Brianf
Haven't used the new EXL Oregon chain, this is supposed to be an improved LGX?
A rim sprocket should last 3 chains. Keep the 3 chains in a set and run with that new rim sprocket. They wear together and will maximize life. Think of it as as gears meshing in a transmission.
Running a new chain on a badly worn sprocket will wear it prematurely and vice versa.
  • Like
Reactions: cjet69
Thanks for the input on the rim sprockets. I let this one go for too long. I made some cuts on an Alder log with the new chain installed. It cut nice and went thru the log like butter.
1 - 3 of 3 Posts
