:Welcome1: :OHCAN
Enjoy all of the many Forums here on MTF..
Don't forget to register what Province the you are in!! Click here
Thanks for the great info John!Hi and welcome, nice to see someone else from the 'Cold North'.:OHCAN
Nice rig there. :fing32: I also have the exact same machine with a 17p cart. Here is the link.
http://www.mytractorforum.com/showthread.php?t=151398
It's a fantastic machine! Great engine, reliable, fine fit and finish. Very well made for a lawn tractor. Better than anything else you can buy from a 'Big Box Store' like Home Depot (I got mine from JD). But, that's my point. It is a lawn tractor. Yes, it will cut grass on 4-5 acres, no problem, but I hope it's flat and that's ALL you want to do with it.
You have much more land than I do, and I'm getting ready to jump to an X700 series or probably even a 2305 SCUT, because, well as nice as the LA130 is... well you'll see in time. Not to say the machine is bad, not at all. It's a wonderfull machine, so long as it's used within the manufactures intended goal. It is a lawn tractor, not a garden tractor. It's not up to par with the Select series in terms of durability, by far. The select series are orders of magnitude above the LA series. If you're planning on towing some weight (you mentioned a larger mower setup) like a roller, aerator etc. over your 4-5 acres, the transaxle might/will give you grief in the long term. Sorry, just the facts.
Based on your size of land, in my honest opion and experience, you might have been better with at least an X500 Series for, if anything at all, the transaxle.
My biggest gripe with the LA series is how difficult they made it to do simple things like take the deck off to clean it. Lots of pins, washers, arms and grunt work. The guage wheels don't rotate sideways so you have to have to tug the deck out against the wheels. The spindle grease plugs are set at an angle that makes it hard to reach with a grease gun (had to change mine to 45 deg angle). The front wheels use plain bearings (bushings). For $20 I replaced them with real ball bearings from JD on day 1.
As for adding a blower, If I was you, I would run (not walk) to JD and upgrade to a Select machine before dropping some coin on an LA blower. It will eventually come down to this, so either do it now before machine starts to age or do it eventually. But it will happen, just as sure as the sun will rise tomorrow.
Just my 2 cents of advice.
Again, nice rig and welcome.:trink40: This forums got a ton of usefull stuff and great people.
-John
Here's an idea, put 'er back on Kiji with 25 hours on her (keep the cart). Think it over, seriously. You'll really be pushing the envelope of an LA series, and might end up chewing it to death in a season or two and how much will that then have cost you in retrospect? An LA series blower WILL NOT work with a select series machine....I bought my JD used on Kijiji...
...(bearing) Part # was on those?...
Hey Randy, Thanks for the info! You're probably right about people selling their 100 series to upgrade, the only thing I found when looking around was that a physically bigger and older tractor in the same price range usually came with a smaller engine with less horsepower. And was much older: 20-30 years older!Luc, welcome from your neighbour to the west . John made some very valid points. You will see plenty of the newer L and LA series mowers showing up for sale. Buyers realizing that they should have bought bigger/older/stronger machines.They are a great machine for what they were built/designed for : cutting smaller RESIDENTIAL lawns. Wish you luck with the 300 foot driveway, you WILL need chains and some how some serious weight on the back, Manitoba like Saskatchewan can get some nasty snow storms. Randy
Not being mean to any LA owners (I'm one of them), it's like comparing a Yugo to a Lexus LS460L. There is a reason for the $100,000cdn dollar gap (for the cars, not the mowers)....the x300 is much more expensive. Why is this?
No offence, but horse power is unfortunately miss used for marketing purpose.I understand how a tractor with a bigger engine would be better, and maybe I'm missing something, but as far as I know, Horsepower is Horsepower. So technically my LA130 with 21HP engine should be better than my wife's grandfather's older x300 model with 17HP. But comparing the two, the x300 is much more expensive. Why is this? Build quality and parts used are one thing, but its not a small difference! Even then, a better built tractor and frame mean that it'll likely be heavier, so that 17HP is even more restricted.
Well now I know how to buy my next tractor! But you guys have to give me some credit... I did buy the right color tractor! Good 'ol John Deere Green!
Thanks for the warm welcome! I look forward to learning a lot about this little piece of machinery, and worst case scenario, if my LA130 quits, I can get one of my wife's uncles to come over with one of their many JD Combines and make quick work of my few acres! LOL
I'm looking forward to making my few modifications and personalizing my tractor.
Un gros merci à Stladrill pour tes videos très descriptifs sur Youtube! Après tout, c'est grace à toi que j'ai trouvé ce site!
For those of you who don't speak french:
"A big thank you to Stladrill for your descriptive Youtube videos! After all, its thanks to you that I found this site!"
