John, 1st off a BHoe is nearly impossible to cost justify in home owner/estate useage. There simply isn't enough work for a BHoe that costs roughly 5K extra. One can rent a larger industrial sized BHoe to do the limited jobs and save $$$.
That said, I have the smallest OEM TLB offered in my BX23 and even tho I've yet to cost justify the small BHoe on it, haveing it ready and onsite when I need it has proven to be priceless. I've installed a thumb on it and now use it way more for wood processing than digging, but again, it's the strong silent helper I've always needed and it's at my beck & call
The BHoe offered for the new B series are bigger and more powerful than the one on my BX23 but it's still not an industrial strength TLB. It'll work hard and all day long for you but Kubota makes an industrial strength TLB in the same size, that should tell you something.
When your doing heavy FEL work, you should have some kind of counter balance on the rear of the tractor to keep it from overloading the front axle/wheels. Many folks use a ballast box or other large implements to provide ballast, a BHoe is probably the best counter ballance you can get.
I have no experience w/the new B's but I can mount the same implements on my BX23 w/the Bhoe removed that can be mounted on the non TLB version of my BX (the BX2230). the BHoe subframes on the BX & B's are design so as to not limit 3ph useage. you shouldn't have any problems.
Kubota designs their quick attach BHoes & FEL's to be mounted/dismounted w/minimal effort and without tools. With experience you can probably mount/dismount them inless than a couple tooless minutes. Thats all it takes me.
I'm glad I purchased the TLB version I did. My BHoe rests on it's stow dolly about 85% of the time now but, when i need it, I need it and thats priceless to me.
Good luck
Dave
Good luck
Dave
