Just got a new Champion Air Compressor. 5hp, 60gal vertical tank, twin cylinder, 2 stage. Motor is a Baldor Reliance Industrial Motor 5hp, 208/230 volts, 23.5/21.5 amps. I have a 30amp breaker in my shops panel box that is not used. Is this OK to use amp wise? I will be running 8ga wire from the panel to a disconnect. Which leads me to my next question. I have a 30amp disconnect that I used for my old compressor, (2hp, 20gal tank), to turn the compressor on and off. On the inside cover of the disconnect it states that the max hp for the disconnect is 3hp. Can I still use this disconnect? If I can then I'm going to hard wire from the disconnect to the compressor. Note that my compressor does not have a manual or magnetic starter. Attached are couple of pics of the disconnect that I hope I can use. :trink39:
