Here are some pictures. It came with a mower deck and ag tires. I mounted the turf tires on.
It runs good with no knocks or smoke.
As soon as I got it off the trailer I mowed my back field. It cut great and was more fun than I’ve had mowing before. Just as I finished I realized the deck blades were not spinning. I found a pulley on the lawn and it is the right mule pulley. The bearing seized and snapped the bolt.
I pressed out the bearing before researching and ruined the pulley! Didn’t know to drill and separate the halves!
I need help with part numbers for the pulley for the 140 mule.
All lights work but the voltmeter does not move. I’ll check to verify charge with a voltmeter to rule out the meter or regulator.
It has zero braking with the pedals down but there is some material left on the pads- can I adjust the brakes or could there be too much pad worn away?
I wish to add a sleeve hitch and rear pto and need advice.
I am looking at a little buck front loader for it.
I will change the fluids on it- what should I use for oil weight and hydraulic? I only located a filter on the transmission.
The mule is missing the plastic knob, protective cover, and legend- I’ll order those parts.
This is likely repetitive material for the forum but any advice on what I’ve listed would be appreciated.
Thanks!
