Frist off we need to know what engine or a picture and deck belt whats the numbers on the deck theres only five or ten belts for those decks
Ok. First just forget the belt. I can get that locally. My engine is a Kohler Magnum 12 horsepower. 471527Frist off we need to know what engine or a picture and deck belt whats the numbers on the deck theres only five or ten belts for those decks
I am glad somebody finally has some parts. But all I need is the fan and the grass cover for the M12. Look at this site and its #7 and #9. Both of them should be plastic. They bolt right on to the flywheel. See what you think about that and then shoot me a price. It might be Friday before i can pay you though if thats ok. If you can, send me some pictures of these 2 just to make sure they are right. And if you can get a close up of the bolt patterns. I just want to make sure this will work. Thanks alot for everything. Dustyhello, i have everything for that m12 kohler except the carb -i bought a bolens 1250 with that engine in it and it had a broke rod- i will send you the bearing plate with a good starter- the sheet metal- block everything for say 50.00 plus shipping- to ten. would probably run you another 25.00- so let`s say 75.00 and i will pack `er up
