This may be a thing that’s been covered before, if so, please forgive.
I am in the process of cleaning and rebuilding the carb on a JD322 I have ordered jets gaskets etc. the problem being JD has the main jet listed as NLA. (Carb is currently in its bath. Unfortunately the PO or mechanics previous had boogered the screwdriver slot on the top of the main, so- we’ll see if that does the trick . Seeking a source for that jet- unfortunately with it swimming and stuck I cannot get a pt# size etc.
It is possible that this "146-0396" jet for a Onan P216 would work as they used a Nikki carburetor I believe is very similar, I am not a 100% sure but it is worth checking out.
So very close!
That one is a
120, I'm needing a.124 the.one.in.it.is functional for now but at some point I will HAVE to replace it. If I cannot find the.124 by then I may need to go larger or have.a.shop Port out a 120. I cannot afford to run that animal lean on fuel under load.
