I'm trying to get the brake disk, item #86 in diagram off the shaft, item #46. Looks like a press fit with a key. Anyone have any experience with this. I've already removed the brake pad holder mechanism.
Gun Toting Democrat.
Hmmmmmmm have you tried something like a gear puller? I'll bet the key is not in there straight and it is wedging itself between the shaft and the rotor.
15,000 +posts!
Those rotors are cast iron and break easily,so beware...I'd use a lot of penetrant and maybe something like a ball joint pickle fork to pry it off,trying to put all the pressure as close to the center of the hub as pssible,not the outside edges..if a bearing splitter collar will fit behind it then one of those with a puller would be the best way...a little heat wont hurt either..
