I'm going to be buying a riding mower, 42 or 46 inch, from Lowe's, and I need some advice. I'm buying from Lowe's because I have about $500 in gift cards from there, plus I get a 10% discount for being retired military. I need a mower that is reliable, simple to service, and comes with a good warranty. I know that is asking a lot, but hey, you never know until you ask, right? My yard is maybe 1.2 acres, completely flat, with only a few trees. I don't want or need a zero turn mower. Any help or guidance would be very much appreciated!
You'll have to buy used to get a command as they quit making them years ago.
The 7000 series is based on command twin and a good engine and for the record the courage twin is good too (about the same as 7000)
The courage single did tarnish Kohler's reputation a lot but the design of engine is fine - arguably better than traditional sump engines.
You could rebuild the entire engine even replace crankshaft without ever removing the engine from the machine if you wanted to and no low base gasket to leak!
It was the execution (tightening the top front 5 bolts) that killed them.
All the ones up to 03-04 have mostly self destructed.
Only seen 2-3 2006 with loose bolts but no damage.
Never seen any 2007 up with loose bolts.
I don't see 100s of these but I do see a lot and keep track of them.
My biggest gripe is twin cams. Not necessary.
Not that they are problematic but not as good design as one cam.
If they had one cam they might be my favorite recent single riding mower engine.
But briggs 31xxx and 33xxxx get the vote.
Sure they blow head gaskets when not if...and I think the acr cam problem is an epidemic (did another last week) but rarely any catastrophic failures and parts (new and used) are beyond plentiful and really cheap!
Sure the single command is 3 times the quality of the briggs but the an owner who does own work will likely have higher cost of ownership with the command as they will all eventually need a coil, carb (or needle and seat) and the Kohler will set you back more in parts.
Now for the average owner who can't do anything more than oil change (or can't do anything but operate it) the briggs is going to cost them more because one trip for a loosened up exhaust rocker stud and/or bent push rod will be more than a coil or carb on a kohler and the briggs has this extra potential issue and head gasket and ACR issue and eventual valve adj causing hard to start/no crank over.
Also people buying twins od 42s (even 46) are wasting money and going to have more repairs and spend more on these repairs than singles.
You don't need 22 hp or a twin on a 42 inch.
Also no logic to any "more hp doesn't have to work as hard" ideas either.
Anyone can disagree all they want but my post is extremely accurate.
It is very valid. Just because a box store model may meet a person's needs doesn't magically change it from being a light-duty piece of equipment. Quality of construction should always be considered even if the equipment meets current and/or future needs.Using the arguments that most all at a big box store are lighter duty lawn tractors is not valid because I said IF a machine meets your needs.
Something I can agree with.If you need a garden tractor or commercial duty ZTR then the machines at the big box DO NOT meet your needs.
Not true. Go tell the Husqvarna owners that their bent frame is no reason to move on to something else. After all, it's an easy fix. 🙄The frames decks wheels axles etc are never the reason a mower us given up on and replaced. It's the engine or transmission.
You are correct. With enough use/abuse, anything can break. That said, I'm quite certain most buyers are not looking for something that is easily repairable. Most are looking for something that is durable enough to not need continual repair and is easy to use and maintain relative to the amount of money they are willing to spend. This may or may not be achieved with a box store model. I would bet most shoppers are unsure.The zero turn frame and tubing wheels brackets can all be bent and damaged on any of them...but can be fixed more easily too.
I'm curious, how many pieces of equipment must one own before they are considered to be "qualified to give a really knowledgeable comparison."Let me say anyone who only has owned a couple to few of these is simply stating opinions or repeating what they have read on internet of reviews(like they are accurate!) and not really qualified to give a really knowledgeable comparison.
I would stand to guess that what usually causes the problems is low quality/poor engineering and lack of or improper maintenance.Techs who see hundreds of these a year are the ones whp can tell you what causes the problems.
The brand is fairly insignificant!
The parts on the particular machine is what matters most.
The K46 is fine. There are over 56 versions of them, some with locking differentials and heat treated steel gears. When used as designed they are one of the most reliable transaxles.This brings us back to K46.
I wouldn't have one.
Sure I've seen 100s over 10 and 15 years old dioing fine for owners but I wouldn't want to have one because I have seen more fail than I consider acceptable.
Actually, no. Today's equipment is precision designed using the latest CAD technology and advanced materials and manufacturing processes. CAD has allowed manufacturers to design and build products that are superior in nearly every way compared to the good 'ol days of pencil, paper and a protractor.Everything in mowers is inferior to what used to be standard.
They have watered down everything I can think of.
They give them fake features or "on paper" features and have skimped in quality to keep prices lower.
Prices have been flat for a long time.
Speechless."Downward spiral to crap" is what I tell customers.
Not sure what you're referring to, Cub is currently selling tractors with Commands.
https://www.cubcadet.com/en_US/lawn-and-garden-tractors/xt3-gsx/14RD3LE-010.html
There have been two warnings from staff to keep this to the original topic...if someone wants to start another thread about any of the matters without getting argumentative please feel free to do so. The next post that takes this thread off its intended course....which is supposed to be friendly discussion and guidance for the OP will cause the thread to be shut down to any further discussion....Please keep it civil and on track...Thank you
Gosh! I just realized this thread is from July of 18 so I can only assume the poster already bought a new mower. What did you buy? How is it working out?
I'm still wondering why someone would not want a zero turn but I do understand there are certain Properties or needs that make them not the best suited for the task at hand. As far as ease of operation and use they are far more enjoyable than a riding mower.
Accurate by whose standards?
With your implied expertise, you should be the first to understand that failures of this unit are due to overuse and poor maintenance (a common theme so far). This is because real equipment costs real money.
As a result, Mr. Hilljack goes into Lowe's and buys a JD S170 to mow 44 acres weekly and pull 35ft trees, 16" round, up hill from his creek flats.
As expected, the tractor fails quickly resulting in him calling JD's "junk" and you not ever wanting to own a K46.
Yeah, doesn't make sense to me either.
Today's machines are designed with the modern consumer in mind and generally provide a near perfect balance between price and durability at any given price point. The modern design and manufacturing process allows for an OEM to offer a much wider array of products because costs can be controlled much tighter. We see this in the JD 100-series line, for example.
Price has not remained low due to "cheapening" (reduction in quality) as so many assume. Many think that because a thicker piece of steel was replaced with a thinner piece of steel quality has somehow been lessened. This is not necessarily true. Perhaps the original part was over built for its purpose or the new part, while thinner, is made from high strength steel and is actually the same strength (or stronger) than the thicker part it replaced. The video below illustrates this point:
WATCH
Instead, prices have remained low thanks to robotic assembly, cheap overseas labor, advancements in raw material development and application, and LEAN manufacturing processes.
Of course, I'm certain you considered all these salient points when forming your opinion.
Speechless.
