I originally planned to mount my engine in the traditional fashion with four fixed bolts and then apply tension to the belt that goes to the jackshaft with a spring tensioned idler arm. The option has come up to slide the motor mounting bracket and tension the belt with a bolt that moves the whole assembly . This would replace an entire pulley assembly with a simple bolt. What is everyones thoughts am I missing something ?
Thanks
Thanks
