Ok its a MTD model 606g labelled as a Huskee. It has a Briggs & stratton 18.5 hp ELS motor. The info on the motor is this model 31q777 type 0215e1 and code 0410212e. Bought it new in 05 I think from TSC and use it to mow and plow. Since new has liked to backfire on shut down but by letting it idle down for a sec before shut off usually is ok. Last summer it got to the point where it would mow fine and then quit when warm but start right up and go again then it backfired once and quit. I pulled the head and one of the rocker arm mounting studs had broken and bent the push rod. I replaced both push rods and the head and finished the year with it fine, plowed with it all winter fine and then this year it will mow for 20 minutes or so and then shut off, but again it will start right back up but have very little throttle response. I have cleaned all the fins of debris, tried with no gas cap, pulled the fuel shut off solenoid to see if functioning(it is) and the only thing I find is that some rodent knawed a bit on the coil unit. I can follow the coil causing my issue with heat but why would it restart while still warm? Also does anyone know the part # for the coil I need given my engine info? Thanks for any and all help or insight and sorry for the long winded question:dunno:
