Thanks for the help guys. :thanku:
The loader is mounted on my Bolen's 1050. It is a factory loader, made by Danco. It's a very "tired" machine, that's been in storage and, up until yesterday, hadn't been run for almost 30 years. The hydraulics were not working good at the time it was put into storage. I suspect that the pump may be "toasted", and may need to be replaced, I don't have a guage, or know of anyone that has one to borrow. I'm not sure if it would be worth the money to buy one. My budget for fixing this is about zero, so maybe it would be better to just go ahead and look for a replacement pump of some sort, but I'll try to check, all the things I can, on this pump first.
The intake side of the pump, directly mounted to a small tank, is positioned at the front of the machine, just in front of the grill. The pump (Cessna) is driven from the front pto. It's a nice looking set up. I'd like to at least keep the pump positioned where it's at. Maybe putting a replacement pump at the front, and moving the tank to another location would be the cheapest way to go. There is no filter on the system, so moving the tank and installing a filter, somewhere, would probably be a good idea. It's not designed to be a quick acting loader, like a big tractor, so I don't think it would need too costly of a pump. Maybe even a power steering pump would work. Any thoughts on that idea?
