1 - 3 of 3 Posts
My father-n-law is looking at a 2010 gas burner with tricycle front end. I have not seen it, he says it needs some work but it runs good. The lift does not work and he thinks it is just low on fluid, he saw a leak around the steering motor.
He says he can get it pretty cheap ($1200 with bushhog).
My question is where do you check the hyd fluid level and where do you add fluid?
Any help would be greatly appreciated.
Cotton
The hydraulic fluid reservoir is the transmission case. Most 2010's were utility style and the check plug/fill plug is on the right side of transmission about where your right heel sits on the foot board. I think it takes a 1 inch wrench. Fill it to the top of the fill hole.
1 - 3 of 3 Posts
