You mean they are rusted on? Or you do not know how they
are held in place?
are held in place?
There is no bolt to remove in order to get the front wheel off! If you were referring to the rears, which was your original question, and you removed the rear bolt and it won't come off, then it may be rusted on the shaft. If that's the case spray the hub and shaft with Liquid Wrench (inside the key slot is a good place to spray) and try again tomorrow after it's set out in the sun for a few hours. It may also require a little mechanical persuasion (hammer and block of wood from the inside) to get it off if it stuck on that bad.well a comboof both i suppose i took the bolt out of the front hub there and it still wont come off
thats a option ive been thinking about lolHad that same problem one time, 7 solid days of soaking with lubricant, heating, pounding, and pulling with a puller. I finally had to torch mine off and buy new rear wheels.
