1 - 2 of 2 Posts
Lindeman crawler fan
This hydraulic pump is different from what I'm use to, it has 3iports ?
I assume the largest port is the fluid inlet port.
What are the other 2-ports ?
The small one on the right is marked -A.
The other port is marked -B.
I can't tell from the picture angle, but there are pumps with a builtin flow divider/priority valve that directs the first 3-4GPM to a smaller port for power steering and the balance of the flow to the other work port.
1 - 2 of 2 Posts
