My new to me L130 has an issue with the RIO switch that I can't pin point.The PO had tried to wire around it,I hooked it back up but it still kills it in reverse and I put a new switch in but nothing different.There is a relay on the right side (don't know what it is for)but I unplugged it and it wont kill the motor when backing up with the deck going?Got a new relay but it still kills the motor when backing up with the relay plugged up,un plug it and all is well.But I need to get the RIO working.
One more thing,the hour meter also is not working,I hooked 12 volts to it and it does work so I am thinking there is a ground issue here,( no power to the hour meter either).There is a ground wire that is dangling free on the right hand side with all the other wires.but I don't know if it is supposed to be hooked up cause I don't see the other end.Dont have a wiring diagram either.:dunno::thanku:
