1 - 20 of 23 Posts
Hello and greetings, i am from Toronto Canada, i bought a jd 111 tractor with 338 snow blower, i installed it the other day, what a pain lol. i am missing the spring support bracket that attaches to the right front corner of the frame and hooks on to the support spring of the blower on the right side, it is unavailable from john deere any help would be great. email is [email protected]:greendr:
I'm restoring a 338 and I don't know what part you are referring to, but can you get a pic. I wonder if I need it too!!
PA318's pic doesn't look familiar ??
hey katt, it is #3 in the pic, it should come with the bag of parts with blower, but you should have everything in the diagram except only one of 9a or 9b, i have 9a. oh and this part bolts on to the tractor frame not the blower.
I don't think I have #3#4#5#6 they don't look familiar ??
Also Herd I asked before What is the thing that looks like a shock absorber rapped in black plastic ( or rubber) sleeve.
Here is what my dealer was able to get from JD
1 lift rod and hardware, ( 9a??) 2. Chute rotator rod that goes into lift rod NOT Available ( he gave me one from a different blower but it works) 3. rod for the tensioner spring on mule drive. 4. long steel straps ( braces) left and right. ( herd they didn't fit by about 1/16 inch or so had to loosen 6 frame bolts and tap the frame forward till they went on @ the tractor end. and file the holes a little ( sloppy casting) on BOTH 175's.
My dealer says it's a 338.
I thought it was a 37a but he said no but many parts are the same.
Herd says it's the same as his !! Hey i don't know ??
You've seen the pics a couple of my posts !!
Discussion Starter · #15 ·
phoned all mower parts today, what a bunch of a holes, part cost 15 bucks, he wanted 20 for shipping, i told him how can you charge more for shipping than the part. He pretty much told me take it or leave it. Don't deal with these people. Now i have to find another parts place, preferably one in Canada, any help would be kool.
· Certified Master Tinkerer
Its the lift assist cylinder. Look at the pic I PMed you and you'll see it it mounted right on the auger case to the right-rear of the spout.
Bosman: you need the ballast weights for steering as much as traction. Without them the machine is front heavy. Also check your fronttire pressure and you may want to adjust for the added load.
· Super Moderator
bosman777, sorry for diverting the thread there a little! I'm not sure if the 111 allows for this but some of these tractors allow you to add a ballast box (normally mounts to some rear supports) on the tractor to offset the weight of the snowblower. Then with the wheel weights and ballast you can really get good traction. I'm working on finding one for my 318 right now!
:sorry1:about that bad link bosman, i didnt know they charged that badly for shipping:fing20: i only really used that site for the diagrams and see an estimate on parts, i havent had to buy any yet:praying: thank goodness.
1 - 20 of 23 Posts
